Exhaust soung
I have 2000 H2X 7.4 MPI and it has the captains call exhaust. I have noticed the last 2 days that the sound is partialy muffled with the exhaust open. When I hit the switch to close the exhaust is gets quieter then when I hit the switch again it is back to normal loud as it ever was. What would cause it to get patialy muffled during use?? Could this cause any water to get in any wrong places (ie. cylinders) ??
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I'm 99% sure you'll have the 4 wire system.
Like Bigred said, watch the solenoid and see what it's doing when you flip the switch. If nothing at all, check power to it. If it switches open, then closes right away it could be a bad solenoid or it could be out of alignment. There is an adjustment screw on the back of it and it can be sensitive.
I had one that was showing 12 volts, but didn't have the "jump" in volts to pull it into the open position. In the 4 wire harness there is a cylinder called a Power Commander that provides the extra juice for switching.
Mine turned out to be a bad ground.
