Gauge Issues >
Gauge Issues
Gauge Issues
Old 05-10-2011 | 09:32 AM
Default Gauge Issues
I purchased a new boat and quite a few of the gauges do not work.
The boat has vessel view and all the readings are correct on that but I would still like all the gauges to work.
What is the best way to start tracking down the problem?
rockstar38 is offline
Old 05-10-2011 | 09:44 AM
Power, ground, sending unit
Drock78 is offline
Old 05-10-2011 | 05:29 PM
Rocky, seems like there is an AGI box issue on that boat. I think there were issues last summer with it.
redbud35 is offline
Old 05-10-2011 | 05:35 PM
Does your tachs work, or do they do a needle sweep when you turn the ignition on?
redbud35 is offline
Old 05-11-2011 | 01:34 PM
Tachs and water pressure work but the rest are hit and miss. Fuel works but are inaccurate as hell (found that out the hard way Saturday)
Old 05-11-2011 | 01:50 PM
I just hit mine until they come back on. Have not broke the glass yet.
UrbanDisturbance is offline
Old 05-12-2011 | 06:33 PM
the electric gages are really picky for voltage and grounds because thats the ref signal they use... the sender creats a voltage thru a piezo electric crystal and the gage refrences to the system voltage thru the ground. if the ground is bad the gage thinks the signal is low. if the power wire is bad , same deal. also... most of these gages and senders are really scrap anyway. i bought all new gafrigs and they were inaccurate for the most part and scrap after a year. i would look at autometer.. the glycerine filled ones...
stevesxm is offline
