oil lines
Old 05-11-2011 | 10:22 PM
markodessa's Avatar
Default oil lines
I need the correct routing of the oil lines please. Like oil lines comming out of the engine is the centerone the in or out. Filter first or the cooler, the engine is 454 with oil cooler and remote filter. thanks.
markodessa is offline
Old 05-12-2011 | 01:58 AM
c_deezy's Avatar
The center port on oil filter mount on the engine is the 'IN/Return' back into the engine.
An oil filter flows 'In' from the outside, 'Out' from the inside. So the center port on the remote filter mount would go to the center on the block mount.
As far as routing, I go Block out > Filter > Cooler > Block intake
c_deezy is offline
