29 Fever with a 496mag top speed? >
Old 05-15-2011 | 10:10 AM
Default 29 Fever with a 496mag top speed?
I wanted to see if any of you would happen to know what a newer style (06) 29 fever with a 496mag top speed should be?
Spinletto is offline
Old 05-15-2011 | 10:27 AM
Are you sure its a mag and not a H.O.?
vegaskeith is offline
Old 05-15-2011 | 10:49 AM
Default I think it is
Old 05-15-2011 | 11:29 AM
Only a 375hp mag. The HO's shows that on the cover "MAG HO".
Guessing around 62-64mph. Small motor for that big of boat.
29Fever575sci is offline
Old 05-15-2011 | 02:49 PM
Originally Posted by Spinletto
Wow! That's a Mag. Never seen a 496mag in a Fountain. I would guess 65mph max. Heard the H.O. runs upper 60's-70ish.
Old 05-15-2011 | 03:58 PM
From what I've read Fountain didn't offer the 496mag in the 29, but I could be wrong. Is there anyway that the plastic piece on top could have been switched? Is the engine marked anywhere else?
Old 05-15-2011 | 05:04 PM
Call merc with your serial number, they can give you the info on the engine.
A.O. Razor is offline
Old 05-15-2011 | 05:12 PM
Over here on this side of the ocean up north, where gas is waaaay too expensive, it is more common to see the 496/496HO's and even diesels in fountains. I would think it's more a question of asking what they can do, than what they will do.
Old 05-15-2011 | 06:03 PM
That boat has got to be a slug, way under powered with a 496 375 hp I know sea rays that will out run it
pacalim1965@yaho is offline
Old 05-15-2011 | 06:26 PM
67-68 with a Mag HO is what I have read, so 64-65 and a turd out of the hole with a MAG. If it came from the factory with that motor Fountain will have a performance report on it from when it was built
rexcramer1 is offline
