Prop update on my 272 >
Old 05-29-2002 | 10:00 AM
Team V's Avatar
Thumbs up Prop update on my 272
I had an earlier thread about prop suggestions for watersking.
I've got a '95 272 with a 454 mag (stock), running a 23" mirage plus.
This past weekend I tested a 22" Bravo I, and it worked great! Gets out of the hole much better, and acceleration was greatly improved. I may have lost a couple mph on top end, but it's worth it. I've got one more prop to try for fun, but I'm going to stick with the Bravo.
Water is way too cold for skis yet... but I think this prop is the ticket.
Team V is offline
Old 05-29-2002 | 10:07 AM
Eric1969
Remember to post pictures!!!!!!!!!!!
Old 05-29-2002 | 10:44 PM
toonatime
What RPM with Bravo 22?? I run labbed Bravo 22 at 5000 in 272
but think not labbed might be better at midrange..
Old 05-30-2002 | 10:40 AM
Team V's Avatar
I wound it up to 5100 rpm's for a short stretch, then backed it off. And that was against the current and into the wind, so I'm sure it has a little more.
I could turn 5100 with my 23 mirage plus also, but not much more, no matter what conditions.
tunatime, what engine do you have?
Eric, I'll get some pictures when I get somebody crazy enough to ski! BTW- I looked closer at my wake, it's probably about a foot and half or so.
Team V is offline
Old 05-31-2002 | 11:46 AM
Shooter's Avatar
Charter Member #300
I agree that the Bravo is the better prop. I had a 23 Turbo Vect and then went to a Bronson Hill Labbed 26 Bravo. (also swapped to a supercharger motor too- that helps)...
Shooter is offline
Old 05-31-2002 | 10:35 PM
toonatime
Bajadave..I am 454Mag 385hp...& like the 22 Bravo.
23 Mirage plus is a great prop but getting on plane much
slower.. have a great summer.
Old 06-01-2002 | 01:15 PM
Team V's Avatar
Okay... same as me, is that all you can get from your labbed 22 (5000), or thats only as hard as you push it? I'm thinking I can probably hit the rev-limiter if I tried.
I've got a 24" Stilletto I'm going to try just for grins. It looks like a smaller diameter, so I'm thinking it may work. Maybe a week or two though.
Team V is offline
Old 06-03-2002 | 08:47 AM
I'm using a 24" turbo vector that I've been very pleased with on my 272 (502 mag). If you do a search through the baja posts you will see a detailed prop comparison that I did on this prop and a 23" mirage +. These (turbo vector) props are very reasonable. I'd like to try a 24" bravo 1 and will sometime this summer and add to the previous thead.
slgr24 is offline
tom call
4
10-31-2007 09:01 AM
tom call
10-25-2007 07:45 PM
flatout
Prop Talk
17
09-12-2005 04:55 PM
jcimprover
Baja
5
04-29-2005 08:58 AM
Preuni
8
01-05-2004 08:52 PM
