Need help with kill switch hook up..
I wired mine into the positive wire coming out of the key going to the ignition box. If your kill switch has wires made on it already chances are they are not as heavy as the positive wire going to the key. If so you will be reducing the wire size going into the key. Wire going out of the key to the ignition box is usually smaller like the size of the kill switch wires.
