Most accurate place to check engine oil?? >
Old 05-17-2011 | 05:53 PM
Default Most accurate place to check engine oil??
For you that have been following, i have got the engine back together and running, found cracked oil cooler but i have been checking the oil regularly and have found that the level differs alot on the stick depending on where you check the oil. I have leveled the boat on the trailer, leveled the trailer, leveled the engines and checked in the water and all location are significantly different. What is you take on the matter....where is the most accurate place to check engine oil?? where did the manufacture intend for the oil to be checked?? I had it full on the trailer and was about 1/4" overfull sitting in the water.. Just curous what others tend to do??
290enticer is offline
Old 05-17-2011 | 06:25 PM
Dave M's Avatar
Veteran: Navy
I never noticed a huge difference between on the water and on the trailer. But, I would say that in the water is what REALLY matters. On the trailer, you could take note of where your water line is and adjust the trailer so that line is parallel with the ground.
Dave M is offline
Old 05-17-2011 | 08:08 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Next time on your oil/filter change, note where the level is at both on the trailer as it normally sits or while in the water at the dock. Then use those 2 as reference points for future oil level checks.
I never worry if it varies a little. A 1/2 qt either way is good enough for me.
US1 Fountain is offline
Old 05-18-2011 | 01:22 AM
The engines should sit level with the boat in the water at rest and that is where you should check the oil.
Griff is offline
Old 05-18-2011 | 06:14 AM
Dean Ferry's Avatar
Veteran: Air Force
+1 always check in the water, at the dock.
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 05-18-2011 | 06:07 PM
thanks, guys. I will note where it is on the water and on the trailer in the driveway for a reference.
Old 05-18-2011 | 06:32 PM
After your next oil change add the proper amount of oil, then you can check it on the trailer and make a scratch on the stick, then check it in the water and make another scratch on the stick. You can scratch a small letter next to each so you'll know which is which. then you never have to worry again.
fastdonzi is offline
Old 05-18-2011 | 06:56 PM
Ginger or Mary Ann?
So you are saying boat builders will determine how the boat will sit in the water while at rest, and then build the transom at the correct angle to position the transom assemblies so that the motor/drive is level with the water line?
Old 05-19-2011 | 01:05 AM
I'm not saying its exactly 100% level, but if you look at 90% of performance boats out there, the engine(s) sit very close to level while at rest in the water.
Transom angles on most brands of boats are all within a couple degrees.
Griff is offline
