502 MPI Buzzer Noise Codes >
Old 05-20-2011 | 10:47 AM
seafordguy's Avatar
Default 502 MPI Buzzer Noise Codes
Buddy has a double buzz at idle. Does anyone have a list of codes for what the buzzers mean. I believe this one is a double buzz once a minute or so at idle - nothing steady.
seafordguy is offline
Old 05-20-2011 | 02:19 PM
dont know about the double buzz, but an intermittent buzz is a stored code and a solid alarm is either OP, drive oil or overheating
Pete280 is offline
Old 05-20-2011 | 08:47 PM
Ted G's Avatar
Read this :
http://www.offshoreonly.com/forums/d...an-1-00-a.html
and you can pull a code. If there is no code then it is most likely a bad idle air control. I don't know why but a lot of times the 2 beeps every minute seem to be an IAC. And it will not set a code.
www.cbpba.com
Ted G is offline
Old 05-20-2011 | 09:56 PM
seafordguy's Avatar
WOW Ted - Thanks.
He was already going to throw an IAC at it in hopes that was the issue, but the rest of that could prove priceless the next time an alarm goes off.
