bonding hull & deck question?
I'm in the process of glassing the full deck to the hull (27 Mag sport) it's a bare hull so access is no problem to the inside perimeter...........I've already bonded an area (deck to hull) above the transom with Vinylester & 1708 (I sanded off all the paint down to fiberglass in order to get a good secondary bond) My question is, If I use epoxy do I still have to sand off all the paint in order to get a good bond like you would with the Vinylesters? ......It's a very tight squeeze in the other areas ahead of me and just want to know the best resin to use that doesn't require all the paint to be off for a decent bond. Also, What type fabric works well with Epoxy in a very tight curved area?................Thanks
The cleaner & better prepped the surface, the better the adhesion & strength. Regardless of which resin used.
J
J
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
I guess what I'm askin' is, on poorer bonding surfaces what is a more tenacious laminating resin Vinylester or Epoxy?.......the area I intend to bond together (deck to hull) at best would still have a little paint leftover on the surface of the areas I intend to glass together...........Thanks
I think both products will bond well to just about anything that's oil and wax free however the real question is how well the paint/etc. sticks or bonds to the surface it's on. I can imagine it's difficult in some areas to have it all prepped perfectly however just do the best you can and then some and go a head and glass it with either or. As long as you don't have long stretches of areas that aren't stripped/ground back you should be fine. I ran into a very simular circumstance recently. I figured if I did the best I could as I want it to last and be as strong as possible that it was probably more than a lot of shops would do that do it everyday. Good luck.
John
John
As I mentioned getting as much off as possible is best. The more grip the better.. However, yes the epoxy will still be a better product to use & stronger than other resins would be..
Jamie / Lakeside Restorations
I decided to go with epoxy on this job and also ordered some 12 oz. double bias cloth...........Does epoxy resin (generally) need any thickening when wetting out?..............Jamie & John -Thanks for all the insights
No, you should not need to thicken it. Actually the more resin that penetrates into the glass & material the better in your situation... You could also always put more than one or two layers of material in there if you wanted to..
J
