Tapping into a hot lead
Old 05-24-2011 | 06:33 PM
Default Tapping into a hot lead
When installing electronics, what is the best method to tap into a hot lead. I read some where on here that you can cause pretty good damage by connecting to the wrong hot.
thanx
bert4332 is offline
Old 05-24-2011 | 06:42 PM
Depends on what you are hooking up & what kind of power it requires. Most gauges and small electronics can be hooked to the fuse block (best place) things that require more amps should be connected at the battery or battery switch.
fastdonzi is offline
Old 05-24-2011 | 07:32 PM
Fuse Block? Is that a terminal block?
bert4332 is offline
Old 05-24-2011 | 07:52 PM
Yes "But" you will have terminal blocks for - (neg) also (it will usually have a majority of black wires) the one you want will have fuses in it and most of the wires will be red or purple.
Old 05-24-2011 | 07:54 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Kinda. A fuse block is a terminal block, but with fuses for separate circuts.
A ground terminal block is a strip of brass with multiple screws for attaching several ground leads.
US1 Fountain is offline
Old 05-24-2011 | 10:52 PM
I'm assuming the fuse block is located under/behind the dash?
bert4332 is offline
Old 05-24-2011 | 10:59 PM
Lofty's Avatar
and I thought this was a thread about motivating my sales staff.
Lofty is offline
Old 05-25-2011 | 01:56 AM
What are you connecting????
Griff is offline
Old 05-25-2011 | 06:59 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I tap into a blank ACC switch with a piggy back connector for something like adding a portable satellite radio.
Baja_342 is offline
Old 05-25-2011 | 07:41 AM
Led lights, separate switch
bert4332 is offline
