496 just makes a click?
boat started fine last year and has never been operated since the last time it was started! not sure how a starter would fail just siting for 9 months. the drive off that engine was removed and reinstalled could that have something to do with it?
When the switch is in the "off" position, no power is coming from the batteries to anything. With the swith in "both" the batteries are combined to power everything. With the switch in either "1" or "2" only that battery is on.
off is off, both is pulling or charging from both, 1 is batt 1, and 2 is batt 2, as far as the clicking, may be starter or batt or could be the contacts in your starter relay, had one do this and thought the same, new battery and starter later, still clicked, pulled relay apart and cleaned contacts, never clicked again
A big thing to remember is DO NOT turn the battery switch from any position to OFF when the engine is running. This can fry your alternator. It is good practice to never touch the battery switch while an engine is running.
ok I have to ask(LMAO) where did you come up with the idea for your user name to be dogturd? thats so funny!
