502 Heads?
Old 05-25-2011 | 10:12 AM
Default 502 Heads?
I've recieved some great advice on here before and I've got another question. My mechanic had to pull my motor because of some rusty crusty manifolds that we were replacing, and the further he gets the more work their seems to be. The heads are looking pretty crusty as well and I'm trying to find out what the best bang for the buck heads are or where to source some reconditioned heads. It's 502 Mag with EFI. Any info would be great. Thanks for the help
Brent
jetheadracer is offline
Old 05-25-2011 | 03:00 PM
summit
VegasHallett is offline
Old 05-25-2011 | 04:38 PM
I'll check it thanks man!!!
Old 05-25-2011 | 04:44 PM
Was it a salt water boat??? If not, I find it hard to believe that the heads are that corroded that they can't be boiled and cleaned up and have a valve job, guides and springs installed.
Griff is offline
Old 05-25-2011 | 05:42 PM
It wasn't supposed to be..........it was my first boat so this has been a learning experience.
Old 05-25-2011 | 05:43 PM
I found edelbrock heads on summit for wayyyy cheaper than I'd seen them anywhere else. I may go with them if mine aren't able to be salvaged.
Old 05-25-2011 | 05:49 PM
Those are a good heads. Make sure to go with the Marine ones. You need to have the better iconel valves.
GTOFFSHORE is offline
Old 05-25-2011 | 07:18 PM
Make sure you understand that they "wayyyy" cheaper part may be because they sell them individually. You may be looking at a price for one head and assuming it is for the pair, and make sure you add some $$$ to the price of the heads for prepping them for marine use.
wjb21ndtown is offline
Old 05-25-2011 | 09:55 PM
Ok not wayyy cheaper I didn't read the description very well.
Old 05-26-2011 | 01:16 PM
TomFTM's Avatar
I have a set of bare casting gm rect gen 5 cylinder heads for sale if you need them. They were on a fresh water cooled motor. Tom
TomFTM is offline
