Prop,s
Old 05-25-2011 | 06:07 PM
Default Prop,s
Looked around the site for info on Props???? I'm getting ready to install a 502/500 plus HP into my 25 Outlaw....Home/shop built without the catalyst converter that now is only on the shelf at Merc factories....
. .Bravo 1 with 1:50 gears....I believe I read some guys asking other questions about their 502/525 HP but can't find one now to ask what Prop they are running!!!!
Thanks Mike Tampa Bay
1stoutlaw is offline
Old 05-25-2011 | 07:03 PM
what engine and prop were you running before. I would think a 25 mirage would be a good starting point.
getrdunn is offline
Old 05-25-2011 | 08:26 PM
25 Mirage Plus for best top end or a Bravo 1 24 or labbed 26 for best all around.
Griff is offline
Old 05-26-2011 | 10:30 AM
Default Prop
For a true 500 hp The 25 mirage plus will have to be stepped up a little or a little cup added. A 26 bravo 4 blade will be your best prop choice. If you are low on rpm's then have it labbed. Should run 69-72 on GPS depending on how well you get the prop dialed in and where the rev limiter is set. I am guessing 5300-5400rpm.
Chris
Blueabyss is offline
Old 05-29-2011 | 01:10 PM
Default Old motor
What did you end up doing with your old 6.2L?
BuddyC is offline
