Big Block Flywheel
I am in need of a neutral balance flywheel for a 540 I am having built. Steel is fine. Does it matter if it is a 1pc or 2 pc rear seal crankshaft? I assume the bolt pattern on all of them will work for a bravo coupler. Let me know what you have. Thanks, Joe
I also need a harmonic balancer for an internally balanced motor if anyone has an extra .
