Transom Work in Chicagoland
Hi all,
I'd like to have a local opinion on my transom. I pulled the old Bennett tabs off my Baja 302 the other day and noted some water coming out of one of the lag bolt holes on one side. Turns out one of their hydraulic lines that had just been drilled thru the hull had not been sealed properly. I'm assuming the worst, but would like an opinion from a local expert. And a bid to do the work should there be any to be done... Boat's in Burnham, IL at Millenium Marina.
Thanks!
Mike
Thanks!
Mike
