Loosing Drive Fluid
A friend of mine has a twin engine Chaparel Cruiser with 350's and alpha 1's. One of the drives looses a whole reservoir of drive fluid in about 40 miles. The boat can sit on a lift and not loose a drop for 4 months. No fluid is collecting in the bilge . Any thoughts?
Chris
Chris
Prop seal? It has to be going out so either that or an outside seal. Still should have some water in resavoir after a good run if not it's a bad leak and all just going out. Pull filler screw on bottom probably full of water.
