Cam Shafts (2) - 454 mags 1997
I have two cams from a twin engine boat with Mercruiser 454 mag gen VI blocks. Cams had 347 hours on the meter when pulled. The cam numbers imprinted on the end are 1622- 9337 and the other cam's number is 1622-6192. you will get a complete set of rocker arms and hydraulic roller lifters with each cam. You get one cam, 16 rocker arms, 16 lifters, 16 studs, one distributer gear, 16 spacers, timing chain with gear set. $175 plus $25 shipping.
