496 HO Plug Choice - Confirm please >
Old 05-31-2011 | 09:08 PM
Default 496 HO Plug Choice - Confirm please
I think it's time to replace plugs in my 2005 496 HO. It has 245 hours on it and I doubt they've been changed. Please take a look at the description below to help me confirm my choice. I've read a lot of the posts and I've decided to go iridium and I think Denso unless someone has a compelling reason not to. The followin is from sparkplugs.com and there are probably 20 different selections for the 496. Motor is completely stock and has a miss when she first comes off the trailer and makes it difficult to get on plane. Once running it clears up and no more problem.
Should I change plug wire? Thanks!
Denso Iridium plug 5331 ITF20 .040 $9.99
14mm Thread Size, 11.6mm (.460") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Removable Terminal Nut, 0.4mm Iridium Center Electrode, Tapered Cut U-groove Ground Electrode, .043" (1.1mm) Gap, Heat Range 20
XX14 is offline
