Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Going price for GEL COAT repair ? >
Old 06-01-2011 | 12:38 PM
Default Going price for GEL COAT repair ?
How does $350 sound for replacing two small holes from an arial in side above rubrail ?
with left over gel coat for future use ( 1 quart )
2KOOLPerformance is offline
Old 06-01-2011 | 12:54 PM
Sounds a little pricey but then again I am not sure what the going rate is on such. Sounds like a pretty easy repair and would do it myself.
getrdunn is offline
Old 06-01-2011 | 03:03 PM
with holes apparently you have to stuff with fibre glass, then filler, then gel coat with a number of steps along the way for final finish, but for that price it better dam will be PERFECT
Old 06-01-2011 | 04:03 PM
glassdave's Avatar
Neno the mind boggler
that number sounds about right, even better if you are keeping the qt of gel. At that point the techs only got about $275 in labor at best to work with on a repair that will probably take three or four hours to do. Shop rate for glass work is $85 an hour so it sounds fair.
08 OPA High Points Champion
glassdave is offline
