Engine start up Issues >
Old 06-02-2011 | 07:47 AM
Fountain4402's Avatar
Default Engine start up Issues
Twin 454's and the engines run great. I wouldnt say it starts super hard but it doesnt start easy and I usually have to pump the throttle on each 4-5 times as well. Im looking for these things to start on first turn of the key or at least easier. I was thinking maybe some carb cleaner in them. It't not electrical I dont think. I have new batteries this year and they read fine, also have new slave solenoids.
Fountain4402 is offline
Old 06-02-2011 | 07:59 AM
Could be fuel pumps leaking back fuel or carbs not holding fuel. Have carbs ever been rebuilt? kits are cheap.
jbraun2828 is offline
Old 06-02-2011 | 08:04 AM
i dont know. It shouldnt have a fuel pump since its carbed right
Old 06-02-2011 | 08:08 AM
How do you think the fuel gets from the fuel tank to the carb then??
yes it has a fuel pump on it, but its mechanical VS an electric pump like a EFI boat would have.
dirty carb could be the issue?
gsxr1216 is offline
Old 06-02-2011 | 09:31 AM
ok thats what I thought. It seems the carbs either arent holding fuel or are dirty. What part would you rebuild if they were holding fuel
Old 06-02-2011 | 08:57 PM
Are we talking hours between starts or days or weeks
firehawkcat is offline
Old 06-02-2011 | 10:27 PM
BDiggity's Avatar
My 525sc's sometimes take 8+ pumps when starting cold. Normally the rest of the day is fine, but the initial start is a challenge. my old 454 mpi was turn key & go.
BDiggity is offline
Old 06-02-2011 | 11:21 PM
carbs tend to do that if you leave boat sit for a week or even a few days I think fuel evaporates out of bowls and depending on your carbs you may not have chokes ( mine are hp series no choke ) b ut as was said above once they start mine will start easily they rest of the weekend , so I am not sure you have a problem unless somthing has changed or you are having trouble after they are warmed up
Larry D is offline
Old 06-03-2011 | 04:34 AM
If they're losing fuel could be the needle seats. To check after shut down remove the air cleaner and look down the throttle bodies. You
will see fuel dripping if they are leaking. It is a common problem. When I had carbs I always kept a spare or two. Also may want to make sure your timing hasn't changed. I've seen that years ago in my ski boat.
SkiDoc is offline
Old 06-03-2011 | 07:23 AM
Do a total rebuild on both...
Thunderstruck27 is offline
