donzi 32zf
i recently purchased a 2000 donzi 32zf. i have noticed it gets an awful lot of water in the bottom. does anybody have an idea about what might be going on? it appears all hoses are connected and the thru hulls dont seem to be leaking. one thing idid notice is the drains around the aft fish boxes all appear to drain in the keel. is this correct? any help would be appreciated
Where are you located? A lot of the early 2000ish 32-35s had transom problems. My first check would be trim tabs. Check lines and bolts where the go thru the transom. Also look at motor mount bolts. If the transom is flexing that will cause those areas to leak.
