Formula 233 ls motor swap
Old 06-05-2011 | 09:59 AM
Default Formula 233 ls motor swap
I just bought a 83 formula with twin 305 mercs. Well the first weekend I went out. One of the motors threw a rod. So here is my question. I have to 1987 efi 350 out of k20 puck up trucks can I use them? And what do I need to change to make them work? Only reason I'm asking is cause I already have the motors so trying to keep it cheap. Please someone let me now if I can use them. thanks
obrienracing233 is offline
Old 06-05-2011 | 11:14 AM
You just talking about using the long blocks? Were the ones in the boat carb motors?
picklenjim is offline
Old 06-05-2011 | 01:09 PM
You would need to get new couplers since the 87 is a one piece rear main and if you plan to stay carbed you will either need to get new intakes or slot a couple bolt holes in the manifolds off your 305's
pretty simple almost drop in
flyinlow is offline
Old 06-05-2011 | 01:35 PM
Yea I just plan in using the long blocks I will change the freeze plugs to brass and get new intake manis to bolt the carbs on. I already checked and I can use the same manifolds and risers. Just seeing if any internals would have to be changed.
Old 06-05-2011 | 08:50 PM
You need to change the cams and valves .
REDS32 is offline
