new/rebuilt engine -new oilcooler=water oil mix >
Old 06-07-2011 | 07:46 AM
Default new/rebuilt engine -new oilcooler=water oil mix
Ok, purchased a rebuilt engine with dyno time only(522 535hp/570tq), purchased new oil cooler for obvious reasons
Mechanic install engine etc, test fires and all good couple nites later finishes up misc items decides to test fire again and notices a small leak coming from one of the cooler fittings. No big deal remove and reseal but upon further inspection notices that fluid is oil and water mix-checks dipstick looks ok, removes oil filter all looks good and under neath valve cover cap a slight milky film. Oil cooler and lines are full of oil n water, so we are hoping its a defective cooler and not engine related.
He removed oil cooler last nite and this is his comments
"Well I thought I would see some oil residue on the water side of the cooler but none. I sucked out a lot a milky oil from lines etc. "
The part about some oil residue on water side.....I no we can pressure test cooler, I've already purchased a new one though and wanted some comments on what you guys think, head gasket? Or......any input or ideas. Thanks
paintman is offline
Old 06-07-2011 | 07:50 AM
clean out the lines, try bypassing the cooler for right now and run to get warm..change the oil, and then run on the hose for a while see if it comes back..
ezstriper is offline
Old 06-07-2011 | 08:05 AM
Ted G's Avatar
Could be a leaking intake, this will show up as milk in the valve covers. Sometimes when the heads are cut too much during a rebuild the intake ports will no longer line up properly, causes leaks. Also make sure he used "Perfect Seal" or a similar gasket sealer or they will leak at the water ports also.
www.cbpba.com
Ted G is offline
Old 06-07-2011 | 03:13 PM
Exhaust gasket! Unless your exhaust is new I would replace the gasket between the mainfold (lower section) and the elbow (top section). Water reversion wether its cam design or gaskets will fool the sh** out of you. The motor even when reverting some water can still run very strong, idle fine and never miss a beat. I just went thru this gasket ordeal, cost me alot of time and money! Hope my experience helps you.
Hard Charger is offline
Old 06-07-2011 | 05:58 PM
Ya dont go ripping your motor apart like i did, i put a new cam in it and everyone had me chasing nothing, i changed a head gasket and intake manifold and it was all reversion i welded ss pipe 10" longer and milk in valve covers went away.
pantera232 is offline
