500 efi erratic idle >
Old 06-07-2011 | 09:43 PM
Question 500 efi erratic idle
The motor fluctuates from about 700-800 rpm for about 20 seconds then drops down to 500rpm for a second. It is also slow to come back to idle if you rev it.
What could it be? Iac motor?
Thanks in advance!
soonenough is offline
Old 06-08-2011 | 12:38 AM
Default Fixx
IAC or a vacume leak,
FIXX is offline
Old 06-08-2011 | 12:46 AM
IAC would be my guess.
Griff is offline
Old 06-08-2011 | 05:49 PM
Thanks in advance!
You had the intakes off right ?
Are all 3 vac lines connected back up at the rear of the
intake?.. pcv hose too ?, or check the plenum o rings to make shure they're still in the proper position/groove in the lower intake runners.
JaayTeee is offline
