McLeod Booster Failure >
Old 06-09-2011 | 04:11 PM
Registered User
Default McLeod Booster Failure
I have a 2001 312 Fastech. The seat bottom of my McLeod booster fell out on me when the support piston fully unscrewed. When I try to put it back the other side just spins and the threads won't catch. Does anyone have a diagram or procedure to remove the seat bottom and then repair the piston? Has anyone else had this happen to them? Is it a matter of getting it screwed back in or is there something broke too.
Mike
mdegeneffe is offline
Old 06-10-2011 | 06:24 AM
Audiofn's Avatar
Charter Member #232
Should not be able to happen. Mine stop solid, I could keep my fingure on the button all day. So my guess is something broke in there. May want to try and take it out and pull it apart to see if you can fix it yourself or you may need a new one. It is a PITA to get them out on some of those seats from what I have heard.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-10-2011 | 06:56 PM
Registered User
Thanks...
Old 06-18-2011 | 03:11 PM
Default McLeod Problem?
You can contact Justin at [email protected].
He will be more than happy to help you out.
donzi9769 is offline
