1350 up the bank!!
Old 06-12-2011 | 04:11 AM
Default 1350 up the bank!!
I posted a few weeks ago about a good friend of mine that has the first mercury 1350 here in Australia in a 21 force ski race boat.
I posted that they spun it out a few weeks ago at 100mph, luckily boat and all involved came out relatively unscathed.
It's with sadness that I can report it ran it's first race yesterday and spun again at 105mph. This time with far worse consequences as the boat threw both driver and observer over 50m from the boat, one landing in the water with concusion and cut to the head. The other landed up the bank and sustained injuries to his shoulder and neck. Both very lucky to be alive!
The boat ended up the bank also and from reports is a write off.
Not sure what was causing it to spin. The driver says it would just drop it's nose abruptly at approx 100-105 but either side of that it would be fine. Initial thoughts are the prop was blowing out at that speed. These boats have run merc 6 drives for years with no problems. Could the 8 need different setup height, are dimensions different? Not that it matters now. It's a $210 000 paper weight now
Kurt Hamilton is offline
Old 06-12-2011 | 06:34 AM
Im no expert on race boats, I will leave that to a racer. But it sounds to me that the 21 footer might be a tad overpowered. after all it is 1350 hp. But what do i know...
pacalim1965@yaho is offline
Old 06-12-2011 | 07:53 AM
Do you have any pictures of this boat?
wananewboat is offline
Old 06-12-2011 | 08:45 AM
The turbos wast gate would cause the engine to loose all its power in a blink, causing the boats front to drop.
J Arruda is offline
Old 06-12-2011 | 09:08 AM
pm203's Avatar
Merc 1350 in a 21 foot boat? That just doesn't sound right.
pm203 is offline
Old 06-12-2011 | 09:11 AM
Question
+1
PokerRun388 is offline
Old 06-12-2011 | 09:12 AM
articfriends's Avatar
Sounds like prop blowout, my 27 ft Baja did the same thing around 97 mph, lost bite, dropped the bow, started bow steering violently and just about swapped ends but I was able to save it with throttle , not something you want to do more than once! Smitty
articfriends is offline
Old 06-12-2011 | 09:25 AM
TeamSaris's Avatar
Driver-441
Racer
We maintained a 21 Challenger with a 750hp Banks turbo motor...never had an issue....would just touch 100 back in the day....a lot less power than your dealing with though
TeamSaris is offline
Old 06-12-2011 | 11:39 AM
1350 in a 21 I thought I was crazy! I want to see a picture.
REDS32 is offline
Old 06-12-2011 | 04:11 PM
The 1350 is actually pretty mild considering some of the other motors in ski racing circuits. Almost all the motors are twin turbo (1500hp isn't uncommon). Just google force boats to see a number of them. It the boats a built to handle the power. In this case however something strange has occurred. I'll try and get a picture up of it before the crash
