Speed specs
Old 06-12-2011 | 11:28 AM
Default Speed specs
Just wondering what top end speeds I should be getting for 1988 211 liberator with 464 king cobra outdrive. Outdrive and prop (21 pitch) are in excellent condition, topping out at 48mph and I was sure it ran faster last year.
mrsudz is offline
Old 06-12-2011 | 12:46 PM
What are your RPM's at wide open throttle? Do you know the gear ratio of the drive? I would think that set up would run about 10 mph faster.
picklenjim is offline
Old 06-12-2011 | 01:42 PM
I would guess at somewhere around 56-57.
tinman565 is offline
Old 06-12-2011 | 10:18 PM
I am assuming you have a 460 Ford, not a 464 or 454.
The 460 in a 211 will run mid to high 50's, I have had several friends who have had that combo in the past. A 454 in a 211 will run low 60's.
21" pitch should be about right, with around a 14" diameter.
That engine should be running at least 4600rpm at wide open. I used to run 57mph in Liberator with a 14.5 x19 prop I think, been a few years.
Your engine may be getting tired, a compression test is a good idea
rexcramer1 is offline
