What's my CFM >
What's my CFM
What's my CFM
Old 06-13-2011 | 11:52 AM
Default What's my CFM
I have a gen 6 502 according to the casting # in my '94fever and I have no history or specs on the motor. According to the casting # it's a '96 motor so I know it isn't the original motor that came in the boat. I would like to know the CFM of the Holley carb, but there isn't any list # on it. I got these #'s off it when I rebuilt it last month...Series: 4150, Pri & Sec jets: 75, Pri & Sec throttle plates: 180 and on top of the Main Body #:6R-7867B. Any ideas on my CFM? All info will be appreciated.
Thunderstruck27 is offline
Old 06-13-2011 | 12:02 PM
I found it was a 950 via Google, however, Holley doesn't have it listed anywhere on their carb sheet.
Just found this sheet though. I wonder if that carb is set up for alcohol...
http://tgsperformance.com/holley.htm
arandaz is offline
Old 06-13-2011 | 03:17 PM
My engine is too mild mannered to be running a 950CFM. I've looked all over google myself, but haven't found anything concrete. I'm including a couple of pics for a visual hoping this will help to ID it.
Attached Thumbnails What's my CFM-4150-holley.jpg   What's my CFM-4150-holley_a.jpg
Old 06-13-2011 | 03:59 PM
That's an HP main body.. Maybe some bastard carb someone put together. Maybe an HP830, or HP850?
Eliminator28 is offline
Old 06-13-2011 | 08:23 PM
An HP950 does not really flow 950cfm. More like 850cfm, so it could be an HP950.
Griff is offline
Old 06-13-2011 | 11:36 PM
I'm running a Holley/Prosystem modified HP 950 on my 439. It flowed 830 CFM. I know the base plate is a prosystem design but as Griff said a HP 950 does not flow 950 more like 850.
endeavour32 is offline
Old 06-14-2011 | 01:20 PM
I have a hp950 that has the same casting number on the main body. I put it on my hp500 this past weekend and it ran good. It idled good. Mine has 84 jets in it and ran alittle rich though.
floyd7811 is offline
