Carb'd HP500..... hard to start? >
Old 06-14-2011 | 03:53 PM
SlowPlay's Avatar
Default Carb'd HP500..... hard to start?
Anyone on here runnin the carb'd hp500? If so do you guys have problems getting them fired up?
SlowPlay is offline
Old 06-14-2011 | 04:49 PM
If mine sits for over a month they are a little hard. but only if they sit that long. if that happens, push throttle all the way fwd and start, then bring back once they start. dont pump throttles. when was the last time you changed your plugs?
FREAKY FAST is offline
Old 06-15-2011 | 01:22 AM
Hot starts, cold starts, both????
How are you starting them??? When cold, give the throttle a couple pumps and then turn the key.
First thing to check is if the chokes are working properly.
Griff is offline
Old 06-15-2011 | 02:05 AM
Default fixx
i crank mine over a few times before i even touch the throttles,helps prime the oil system's and gives the carbs a chance to fill up..Then pump a few times and then they fire..
FIXX is offline
Old 06-15-2011 | 08:52 AM
SlowPlay's Avatar
just went over the motors this winter out of the boat. new everything. she was a bear to start before and the same now.
Anyone know the timing specs on these and what to disco to set the timing? Thats the only thing i havent checked.
SlowPlay is offline
Old 06-15-2011 | 10:12 AM
switching to electric fuel pump will more than likely solve the issue. The one I had also had a Barry Grant Mighty Marine Demon on top and that might have helped too. It could sit for months on end and all I ever had to do was turn the key, let the fuel pump prime, pump the throttle twice, and start. It actually started quicker than my current 6.2 MPI's.
VetteLT193 is offline
Old 06-15-2011 | 11:34 AM
Timng should be set at 12* for base timing and it should advance to 32* above 3000rpms.
Griff is offline
Old 06-15-2011 | 02:56 PM
Thunderstruck's Avatar
14 deg at idle with 34 deg total advance. To set at idle you need to short the white/purple wire to ground.
Long time cult member.
Thunderstruck is offline
Old 06-16-2011 | 08:22 AM
I take it that this disables the advance. Is this one of the wires going to the distributor? Does the connection need to be broken and then which end gets grounded?
Hot Tub is offline
