cutting out
Old 06-15-2011 | 06:30 PM
Default cutting out
25 sunsation w/ 454mpi cuts out under load replaced feul water seperator, plugs, cap, rotor, wires, coil, moduel in distributer, charging system working fine, all grounds are good, runs on hose fine but when getting on plane it misses and if running with trim down not to bad but trim up and misses, started all at once he pulled into my docks one day running perfect few hours later went to leave andf it was there.
Thanks For Any input.
rssteiny is offline
Old 06-16-2011 | 07:30 PM
Check fuel preasure, might be ok on hose load is alot different
firehawkcat is offline
Old 06-16-2011 | 09:33 PM
check for plugged injector screens had the same prob on my 502 mpis
johnlaskowski is offline
Old 06-16-2011 | 10:23 PM
Default fixx
+1
FIXX is offline
Old 06-17-2011 | 10:24 AM
Took words right out of mouth!!! That's about all that's left! Or just dirty or bad injector. If screens are good.
+2. P.s. check fuel psi under load for sure too!!!
skydog is offline
Old 06-18-2011 | 07:41 AM
Always good to check and rule out anti-siphon vave at the fuel tank....
johnny b good is offline
Old 06-18-2011 | 07:43 AM
For sure and checking fuel psi under load will do just that.
skydog is offline
Old 06-18-2011 | 12:06 PM
Thanks guys ill let you know what it was.
rssteiny is offline
