Counter clockwise engine fireing order ? >
Old 06-01-2002 | 11:08 AM
B38
Question Counter clockwise engine fireing order ?
I just bought another Chris craft. A 28 I with twin screws. Starboard engine turns to the left from front of 350 ci, rotor turns to the right when looking down at distributor. The only way I could get it running was wires going to the left from # 1. This does not make sense, also it did not run right. Kinda rough like order is incorrect. it did idle. What is the fireing order
of a left hand rotation motor with rotor that turns to the right. I have wires currently going to the left from # 1 = 18436572. What am I doing wrong. Or is the fireing order differant do to the direction. These are 1982 350 OMC in a chris craft. Thanks
B38 is offline
Old 06-01-2002 | 01:50 PM
MKast
The firing order is the same, left or right. Look on the intake manifold for the firing order. On either engine, go in the direction the distributor rotor turns. Trick is make sure you start with the number one cylinder on the distributor cap. In other words, turn the engine over until you find top dead center on the number one cylinder, both intake an exhaust valves closed, compression stroke. which ever post on the cap the rotor is pointing to is number one. Hope this helps.
Old 06-01-2002 | 02:07 PM
NOTING FOR NOTHING, but the rotor has to turn the same direction on both engines.If not, the oil pump just blows bubbles in the pan!try this 12756348 and see if it works Paul
jaf302 is offline
Old 06-03-2002 | 09:29 AM
MKast
In older boats with TRS drives, twin engine applications had a reverse turning engine, timing gears instead of a chain. The distributor rotor turned in the opposite direction. In Alpha boats, the engines turn in the same direction.
Old 06-03-2002 | 12:50 PM
28SS's Avatar
A little clarifaction. TRS drives all use standard rotation. Rotation change is done with different lower unit RH LH. All standard rotating engines and counter rotating engines spin camshaft same dirrection. How this is done is as previously stated. A liitle more info though. Standard using timing chain turns cam and crank same direction.
Counter rotaion uses two gears cam turns orig direction while crank turns opposite hence couter rataing engine. Same cams cranks oil pumps etc. The only difference being gears on crank and cam.
For some of you out there that wonder why some gear sets are used on standard rotation engines they use a idler gear to get crank going same direction as cam.
28SS is offline
Old 06-03-2002 | 04:18 PM
jaf302 has the proper firing order,remember that to advance the timing you turn the dist the opposite direction.And you work off the other side of the time mark on the damper. Doug
Dixie Doug is offline
Old 05-21-2012 | 09:57 PM
Default i have same thing with firing order
i have the same thing as B38 , did the engine ever get running properly ? my engine was running with the backward firing order, but would cut out at about 3600 rpm . should be getting a llot more . i am puzzeled
Ranhot is offline
Old 05-21-2012 | 10:57 PM
This is what a RR motor's cam gear looks like. (one of my 454's)
firing order is: 12756348
f_inscreenname is offline
Old 05-22-2012 | 05:17 AM
Originally Posted by B38
I . What is the fireing order
i think you got the firing order correct. you used backwards (for your cr engine) firing order, but put them on in backwards order. the old double negative thing. pull both caps. both distribs turn same way. you advance the timing by turning the dist the SAME way as standard rot engine. but you hafta ignore every mark on balancer but TDC. might wanna measure how far 8 or 10 BTDC is and put a white-out mark same distance other side of TDC. most marine caps have both firing orders on the cap. standard is on outside. cr is marked just inside other set.
dereknkathy is offline
Old 05-22-2012 | 02:40 PM
firing order is NOT the same, reversed, but dist turns std direction
ezstriper is offline
craig pogue
Drives and Lower Units
1
06-26-2007 03:14 PM
jeff32
06-26-2007 09:43 AM
Buddy OO
03-27-2006 02:18 PM
MnFastBoat
06-07-2004 08:43 AM
seahawk
5
08-05-2003 05:42 PM
