Spraying Gelcoat
I was reading the instructions on Spectrum Color's website about spraying gelcoat. It said the the time before gelcoat reaches its gel stage is 5-10 minutes. I was thinking about using an automotive style gun to do the spraying of a transom. Does that mean that 5 minutes from when I did the mixing, I have to be cleaning the gun?
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
http://www.harborfreight.com/househo...gun-92841.html
this ones a little better for gel if you must use an automotive gun. Gravity feed guns need less air and subsequently cheap ones tend to atomize less which is perfect for gelcoat. For gel you want just enough air to pull the material out of the gun and get it to the surface, as little atomizing as possible. You will need to use Duratechs gloss additive though for thinning. And yes you must work fast
http://www.harborfreight.com/20-oz-h...gun-47016.html
These things are cheap enough to pretty much throw away after a few uses
08 OPA High Points Champion
I didnt go with that one due to the 1.5 mm tip size, I just got the biggest tip size gun they had(2.0), but I quess 1.5 would work with thinning.
I wasnt too upset when I ruined the first one, went back and got 2 more, which reminds me, I gotta build a throttle box to go in front of the new seats that will need to be gelcoated, maybe I'll stop by and get one of the ones Dave suggested
Just finished gel coating the bottom. I found this gun to have great flow for the gel. http://www.tcpglobal.com/spraygundep...o=TCP+G6600-25
I used the throw away cups from harbor freight . Duratec high loss additive works well. Don't spray without it. Thanks to GlassDave for all his posts that help all of us.
. . . . a that price i didnt feel to bad about taking a drill to it
