700hp 24 Outlaw - prop? >
Old 06-27-2011 | 01:41 PM
Default 700hp 24 Outlaw - prop?
Anyone out there running a 700hp motor in a 24 outlaw? If so, what are your experiences with props? I'm looking for a good starting point. Thanks.
arandaz is offline
Old 06-27-2011 | 01:55 PM
JasonSmith's Avatar
What gear ratio and what is the desired RPM up top?
JasonSmith is offline
Old 06-27-2011 | 01:56 PM
1.36 and 6100
arandaz is offline
Old 06-27-2011 | 02:23 PM
good question -- we just took my buddies 24 with an 850 sc out yesterday for the first time with a 34 bravo 1 at 4900 rpm the boat was very bow heavy, along with an ample amount of torque steer.
We are thinking about trying some 29 mirage 3 blades to see if it will carry the bow better.
Hope someone with some expertise chimes in.
delsol is offline
Old 06-27-2011 | 04:59 PM
ok i have 718hp with 136gears .i am running a 23 mirage prop at 5600rpm. doing low 80 plus all the time 100gallons of gas and 4guys. now i put a 25mirage ran 5100rpm 79.4 mph on gps so far the mirage prop works the best http://www.youtube.com/watch?v=jmnD9..._order&list=UL
bajabob is offline
Old 06-27-2011 | 05:03 PM
the 4 blades lift the boat out of the water to much look at my run i trim it to much at the end and it has no boat in the water . so i trim it at 55mph and leave the trim there then go full throttle
bajabob is offline
Old 06-27-2011 | 05:10 PM
the29 will work better. remember the plus is not like the reg mirage the plus truns 200rpms less then the reg mirage the plus lifts the bow more to . i try both i like the reg mirage for my boat .you got to try them and see. i would prop your boat to 55oorpm . good luck
bajabob is offline
Old 06-27-2011 | 05:11 PM
mirage handling is awful is my only concern. I'm just trying to get to my top end power. it could be a variety of little issues at this point. i've had a mach and a bravo on mine and the handling is completely different. i've never went over 70 with a mirage so I'm not 100%. i can see in your video the squirrel toward the end though
arandaz is offline
Old 06-27-2011 | 05:49 PM
if you are runnig 136 gears then you need to run a 23mirage same as me5600 i am over 80try this23prop and see what your rpm are???? what pitch prop have you try and top rpm did it turn??
bajabob is offline
Old 06-27-2011 | 06:38 PM
The handling with the Mirage+ should be better than the old Mirage. I find it settles the stern more. You could also look into the Revolution 4. The diameter is not that big, so prop torque should be minimal. I think the M+ and Rev4 are the best props for the 23-25OL and H2X.
A.O. Razor is offline
