sbc crossover pipe
Old 06-27-2011 | 05:37 PM
Question sbc crossover pipe
Gathering info for a 385 build. Is a crossover system any better than a circulating pump system? Thanks in advance and i'm sure i'll have plenty of other questions. R.
Andrew 19 is offline
Old 06-27-2011 | 06:08 PM
northernoffshore's Avatar
I have some . A set of stainless ones in swap shop and an aluminum one that i would sell real cheap. pm me with your # , jay
northernoffshore is offline
Old 06-30-2011 | 10:45 AM
Crossover systems work if they are done right. Make sure you use a high flow thermostat with bypass holes like a Stewart. Also make sure you crossover system has the bypass tube also. I have a crossover system on a 522 that seems to work real well from Stainless Marine. I plan on plumbing the back water jacket ports on the intake to the front to help balance the flow and reduce hot spots.
ThisIsLivin is offline
