Whippled 500 EFI Injector help!
I have a Whippled 500 EFI that has a bad fuel injector...does anyone know what pound injector is in there or where I can get a matching replacement? I had them cleaned and bench tested by a diesel injector company and was informed that the one was bad, so I told them just to match one up and they told me they can only buy diesel injectors??? I did not know when dropping them off that an injector company could only buy diesel. Sounds weird to me but that's where I am at and could use some help or suggestions. Thanks in advance!
Many times injectors don't have a part number on them, which can be problematic. I had my injectors cleaned and flowed at WitchHunter Performance. They did a before and after flow/spray pattern analysis. That should tell you what the flow rate for the injector is. Prior to that I knew nothing about the injector other than the brand (Keihin).
Is the injector spray and flow bad? I had one that flowed poorly and had a poor spray pattern. They were able to clean it and get it working correctly again.
Ideally, I would just like to get one to match the set I have and then get a new set for next year...I just don't know anyone that can do it.
