HP 500 fuel/water pump >
Old 06-28-2011 | 05:56 PM
Default HP 500 fuel/water pump
What type of oil do I need for my 1995 HP500 fuel/water pump?
Jeff Williams is offline
Old 06-28-2011 | 06:24 PM
I filled both of mine with the same oil I run in my Bravo outdrives.
tinman565 is offline
Old 06-28-2011 | 06:47 PM
That is correct! It calls for "high performance gear lube" any traces of gasoline smell in the old oil and you need a new fuel pump.
00 Daytona 22 is offline
Old 06-28-2011 | 07:01 PM
1 MAIDEN AMERICA's Avatar
Mine is always full of fuel. Replaced both pumps and same thing next oil change. So I just change the oil every 10 hours. I'm glad it's not going into the engine. I don't have drains so I suck it out and fill it with a syringe and small hose. It's been fine for years. Also, there isn't anything coming out the vent. Quick Silver HP Gear Oil.
1 MAIDEN AMERICA is offline
Old 06-28-2011 | 08:16 PM
Ted G's Avatar
It will always smell of fuel after a season, no problem.
www.cbpba.com
Ted G is offline
Old 06-28-2011 | 08:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Yep, mine always did as well. Oil was never diluted or level rose, just smelled like gas. Changed it twice a yr to be safe and never an issue.
US1 Fountain is offline
Old 06-28-2011 | 08:48 PM
common problem everybody wants to replace the pump as they think its bad . waste of money .change the oil and all is well .ill bet ive serviced 50 with the same issue . when the pump is bad you will know and the tube will have gas in it .drain and refill w hp gear oil
smokin' gun is offline
