2000 Fountain Fever 27 - 502 Mag - Factory Prop Spec?
Been searching the forums, but can't find what I'm looking for. Our new (to us) boat came with a 22p RH Bravo I prop. Is this the correct prop for a stock 502 Mag for this model?
If not, I'd like to get the correct prop or one that is recommended.
Assuming final drive is the spec ratio.
Thanks.
Thanks.
WOT - Full fuel tank, 2 men, 2 small women, relatively light river current - 63 mph, but the tach was bouncing to 5300 rpm or so - which is a higher than redline (my understanding is 5150 rpm is redline). So seems like I'm "strung out" so to speak.
Thoughts?
Thoughts?
You're probably hitting the rev limiter!
