Cmi Or Dana Exhaust
Did anyone change over the stock exhust manifolds to CMI or DANA exhaust manifolds on a 34 vyper with 496 MAG HO'S? Do thay fit or are the engines to close together? If so any power gain?
Has anyone seen or have a vyper with 496's MAG HO's that had dana or CMI header exhaust systems changed from stock? Do they fit side by side? I was told they mite not because the engines are two close together. Any info would help before I decide to change out the exhaust system.
you may want to call Ray at Raylar all he deals with is 496s and has tested aftermarket exhaust systems and has not seen any gains,,,the stock exhaust is pretty good .
