would Ls6 heads be good >
Old 07-04-2011 | 06:10 AM
Default would Ls6 heads be good
for a marine engine?
mookster is offline
Old 07-04-2011 | 12:08 PM
I have them on my 509 work fine so far...
86242ls is offline
Old 07-04-2011 | 02:37 PM
you would need to narrow down which heads. there was an LS6 with closed chamber and open chamber. the open heads work pretty well. the closed chamber shroud the valve quite a bit. do you have the casting number for the ones you want to use?
compedgemarine is offline
Old 07-04-2011 | 04:11 PM
188's I think is the Q here... open chamber.. used on all high perf Mercs since the 70's...#14096188
or if you really mean the 71 LS heads #3994026 spare them and sell to someone who really needs them ...and get DART Merlins...or go with the early (big) Oval port heads and put 2.25/1.88 valves in them and do a pocket porting/bowl work and you'll run circles around rectangular ports.
MikeyFIN is offline
