Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
question about marine paint and clearcoat >
Old 07-05-2011 | 08:48 AM
Default question about marine paint and clearcoat
i see that some automotive paints can be purchased with clearcoat added in with paint. so it makes the process quicker and no clearcoating needed after paintjob. is there a marine paint like this? or does it need to be sealed with somthing special? thanks
potatoe is offline
Old 07-06-2011 | 09:00 AM
glassdave's Avatar
Neno the mind boggler
Automotive finishes come it two basic systems, single stage and base coat clear coat. Yes an automotive single stage like PPG's Concept works great on boats (above water line). If you are looking for a nice white try PPG fleet number 91050, its a very clean white that goes with any color. The biggest mistake i have seen with do-it-yourself paint jobs is selecting the wrong color, cant tell ya how many times i have heard someone say i got the brightest white they had. Huge mistake. So called refrigerator whites look terrible and will make even a new interior look dirty. I have researched whites for years and stumbled on the factory match to my 38 while doing some warranty work on some 38 ZX's about ten years ago. I was able to get the ppg # from the factory and have used it ever since. Its actually a slightly grey color when you compare it to a mixing base white but on a boat in the sun looks fantastic plus because of how clean the color is it goes with any stripe or interior color very well.
08 OPA High Points Champion
glassdave is offline
Old 09-09-2011 | 11:05 AM
Hey Glassdave,
I've been trying to source this paint since you've mentioned it so many times. I'm about to do a rebuild and thought I might paint, so I thought I'd try pricing this stuff. But I can't find it online. How much does it cost, and where do you get it?
Thanks!
Stan
svonmiller is offline
Old 09-09-2011 | 09:57 PM
Stan,
Check out http://www.tascoautocolor.com/stores.htm this company has several stores in Austin. They are a full line auto paint supplier...
Good luck
Hula Boat Care is offline
Old 09-10-2011 | 08:09 AM
Cool, will do. Thanks!
Old 09-30-2011 | 09:28 PM
Awlgrip says you can mix 10% of the clear into the final (3rd) coat of dark paints
ctuck0659 is offline
Old 09-30-2011 | 09:36 PM
Default fixx
duratec also makes a marine clear,,dont know what it will do to base coats or single stage enamels tho but its some tuff stuff..
FIXX is offline
