Virbation problem, Gimbal Bearing? >
Old 06-03-2002 | 01:57 PM
imq707s
Default Virbation problem, Gimbal Bearing?
I put a new gimbal bearing in my boat this spring. 21' Scarab with 350 and alpha drive. I've just started to notice that when I start the boat up when it's sitting in the water on the trailer and the drive is trimmed all the way up, if I rev the motor to around 2000rpm a vibration starts in the back of the boat, then when I trim the drive lower it goes away. Is that a sign that the gimbal bearing is bad, or is that normal when the drive is trimmer up all the way. Is it just because the shaft it not straight and the u-joints get out of balance? When the boat is running at WOT (around 60mph) ther is no vibration at all. The u-joints looked good when I put the drive back on in the spring. I did'nt use an allignment tool when I put the new bearing in, but I didn't think I had to since I never touched the motor or moved the position. Is that vibration normal at high tilt angles.
Old 06-03-2002 | 02:49 PM
ROLNTHUNDER
This is normal it also will make a strange noise when it is in that position from the u joints at a bad running angle.
Old 06-03-2002 | 03:28 PM
formula31's Avatar
Yea, what thunder said, and you should really not run it over idle when trimmed up over the stops. It doesnt do the u-joints any good.
formula31 is offline
Old 06-04-2002 | 02:36 AM
MnFastBoat's Avatar
Charter Member#157
Talking vibrator
like others have said it is not advisable to start let alone get above idle when in trailer position
I always drop the drives below full trim BEFORE starting.
Now then again with my cat I am able to leave the drives in full down position on the trailer without any trouble.
But if you are in the water already you sould be able to get at least at if not below full trim.
Keep doing what you are doing and you will learn how to replace u-joints The hard way
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
satisfactionII
5
10-24-2005 09:13 AM
bouncedcheque
9
08-15-2005 06:34 AM
CN24
4
01-15-2005 07:25 PM
Bankshot242LS
04-23-2004 01:50 PM
Raven
06-10-2003 05:15 PM
