98 26 velocity speeds?? >
Old 07-05-2011 | 05:11 PM
Default 98 26 velocity speeds??
I got a 1998 velocity with a 525 with a blower built by performance just wondering if my speeds are some what correct compared to others with similar applications? ? 87.8 on gps with a full tank of gasand 98 on the dreamometer lol? Any input would be great thanks ...mike...
rollnhrd is offline
Old 07-05-2011 | 07:30 PM
What pitch prop? and what rpm?
Velocity Tom is offline
Old 07-05-2011 | 07:39 PM
30 bravo 1 4 blade done by b-blades at 5500
rollnhrd is offline
Old 07-05-2011 | 07:41 PM
I could beleve 87 mph.
Old 07-05-2011 | 07:48 PM
i was actually thinkin i should be doing a little better.. i have a garmin gps im not a b.s.e.r lol.. i tell the exact truth not like others i see on here lol
rollnhrd is offline
Old 07-06-2011 | 10:48 AM
gary cook's Avatar
Racer
Racer
Default speeds
mike your speed is pretty close my 26 race with a 30 b blades 1.65 gear does 94.4 at 6500 that engine makes 715 hp.
my backup engine that is 615 hp same set up at 5500 goes 85 mph just to give you some comparsions these are real gps speeds not bs lots luck have fun.
also do you know how much power you are making.
gary cook is offline
Old 07-06-2011 | 12:42 PM
My engine builder said I should be deep in the 700 hundred range .. im running a hair over 6lbs of boost I got 2 800 holleys on it im just wondering if I could knock the jets down a hair.. I thought it would run a lil better but all in all im very happy..
rollnhrd is offline
Old 07-06-2011 | 12:43 PM
Gary, with speeds like that you should be running class 4, not 6!
Fast Shafts is offline
Old 07-06-2011 | 12:56 PM
Ive Had Two 26ft Velocity's.....your Speed Sounds About Right....anything Faster Is A Real Hand Full To Drive......been There Done That!!!! Be Safe!!!
MrSneakAttack is offline
Old 07-06-2011 | 01:02 PM
Its actually not bad with the bigger tabs and hydraulic steering. But I wouldn't wanna go that fast with out those 2 key items...
rollnhrd is offline
