Looking for a Bravo 1 Prop! >
Old 07-06-2011 | 02:41 PM
Default Looking for a Bravo 1 Prop!
Does anyone have a good condition used 28P B1 RH laying around? Im in need of one to try and see if I like it more than my 27P Mirage Plus.
Many Thanks
BBADWS6 is offline
Old 07-07-2011 | 10:49 AM
Bueller...... Bueller..... Bueller.....
BBADWS6 is offline
Old 07-07-2011 | 11:21 AM
What rpm was the 27 at ?
tinman565 is offline
Old 07-07-2011 | 11:58 AM
Im getting 5200 out of the 27, but it likes a LOT of trim.
BBADWS6 is offline
Old 07-07-2011 | 12:47 PM
You know that 28 bravo is gonna pull your rpms down about 400 right ? If you have enough motor to turn it.
Old 07-07-2011 | 01:47 PM
Wow, I didnt realize it would drag me down that much. I was thinking 200 ish. I would like to be around 5000-5100 rpm. I have a B1 24P that over revs way too easy, so it makes me think that a B1 26P will not be enough.
I didnt expect the boat to turn the Mirage Plus 27 as good as it did, but it does. I want something to help me out of the hole, and cruise speed. The Mirage Plus doesnt do too well on the low end.
BBADWS6 is offline
Old 07-07-2011 | 03:50 PM
You gotta figure your adding pitch...wich will lower your rpm some....then your adding ANOTHER BLADE..lol. What motor/combination do you have ?
Old 07-08-2011 | 02:19 PM
The motor is a 502 mpi mag. I read adding a blade takes you down about 100 rpm or so (in my pitch range), and that a B1 is comparable to a Mirage Plus with one less degree of pitch. I appreciate your comments, and hope to get some more input!
I was figuring the B1 28P would be around 4900 ish, but i may be giving the boat a bit more credit that is due in the power dept.
BBADWS6 is offline
Old 07-08-2011 | 02:32 PM
I think that prop i have will work very well on your boat
fastscarab22 is offline
