where can i find exhaust plugs from thru-hubs >
Old 07-07-2011 | 10:55 AM
Default where can i find exhaust plugs from thru-hubs
i have captains calls and i would rather just remove the thru-hub and only have the thru-hull....
where can i find a plug or hole filler for the gimble ring?
morrowcarl72 is offline
Old 07-07-2011 | 10:59 AM
im pulling my motor this weekend for a new oil pump, bilge pump and general cleaning anyways..... so i figured why not just rip that out while i have the motor out
Old 07-07-2011 | 11:02 AM
ok so i found a plate online! is it really just as simple as putting a plate over the hole!???
Old 07-07-2011 | 11:29 AM
Dave M's Avatar
Veteran: Navy
Yup, remove the y-pipe, install plate, done!
Dave M is offline
Old 07-07-2011 | 11:35 AM
yea i never thought it would be that simple! not even going to waist my time buying a plate i have metal and a plasma cutter and a drill not sure what else i need
Old 07-07-2011 | 12:34 PM
Dave M's Avatar
Veteran: Navy
Good idea, Merc charges around $40 for that plate if I recall.
Dave M is offline
Old 07-07-2011 | 02:06 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Those 2 bottom bolts are a mother! Engine most likely has to come out unless your a twisted matchstick?
fireboatpilot is offline
Old 07-07-2011 | 03:27 PM
Use a good sealer.
Griff is offline
Old 07-08-2011 | 01:10 PM
motor is coming out this weekend and i think im going to make a gasket plus rtv it!
Old 07-08-2011 | 01:21 PM
I have the Merc plates if you need some 10.00 each.
ken sampson is offline
