Shaft rockers for sure?
Old 07-07-2011 | 02:12 PM
Default Shaft rockers for sure?
600 Merlin, 1071 BLowen, 6,000RPM 1000+HP
If yes......
T&D or JESEL?
Thank you Skydog
skydog is offline
Old 07-07-2011 | 02:19 PM
GPM
Crower stainless shaft rockers might be a good choice.
GPM is offline
Old 07-07-2011 | 03:37 PM
Tand D are a fair amount cheaper
SHAWN DAVIS is offline
Old 07-07-2011 | 03:58 PM
Default Fixx
T&d all the way,,one piece and are stronger..had a few jessel brake,jessel's bearings ware quicker then t&d's..
dont know about the crowers but the 1500 price tag
FIXX is offline
Old 07-07-2011 | 04:54 PM
GPM
What do you think T&D will cost ?
GPM is offline
Old 07-07-2011 | 05:01 PM
So looks like 100% yes on the shaft rockets then.....
skydog is offline
Old 07-07-2011 | 06:09 PM
Default fixx
depends on who's heads he is using..900-1400
FIXX is offline
Old 07-07-2011 | 06:13 PM
GPM
I thought I read closer to 16 for the good ones, I could be wrong.
GPM is offline
Old 07-07-2011 | 06:53 PM
Depends if you want steel or aluminum rockers and if you want spring oilers t can add up I think I was around 1800 for my T & D for AFR heads
goebel1 is offline
Old 07-08-2011 | 05:30 AM
I bought my T&D sets from CV Products,they were cheaper than buying direct from CV, (BBC Dart Pro1 Alum heads)around $1500 a set if I remember correctly
JoeD is offline
