Timing Advance for GM Vortecs? >
Old 07-07-2011 | 08:04 PM
Default Timing Advance for GM Vortecs?
Anyone have any experience with Max timing advance for Vortec SB heads?
I have heard 30 degrees is the max.
THX
TEXASRPM is offline
Old 07-07-2011 | 09:14 PM
I think I recall that you set em to 8 degrees and they advance to 32 max via the ignition module.
NHGuy is offline
Old 07-07-2011 | 11:43 PM
28-30* max timing is what I have read.
Griff is offline
Old 07-08-2011 | 12:05 AM
Post
I also think like this.
ella.boswell is offline
Old 07-08-2011 | 07:08 AM
GM vortecs are different, 32 sounds like too much. The chamber burns faster and there is a hot spot that can cause detination. Someone that knows the facts will certainly chime in.
jeffswav is offline
Old 07-08-2011 | 04:13 PM
if you upgraded to the vortecs on a std engine 26 is it !! otherwise 28
ezstriper is offline
Old 07-08-2011 | 10:18 PM
I have mine at 34
87MagnumII is offline
Old 07-08-2011 | 10:21 PM
Originally Posted by 87MagnumII
I have mine at 34
What heads do you have? I have mine at 36, vortecs are different
jeffswav is offline
Old 07-08-2011 | 10:24 PM
Mine are not the 062 heads, I can't remember the number right off but they are vortec they used them in heavy duty trucks and what not
Old 07-08-2011 | 10:25 PM
I have 906's
