BW Trans question >
BW Trans question
BW Trans question
Old 07-10-2011 | 11:37 AM
10M
Default BW Trans question
Hey guys,
I have a feeling the answers are not going to be good, but here goes...
'88 10 Meter w/stock 454s and Borg Warner trans, TRS
Was running pretty hard the other day and one of the tachs jumped up to 5k. It was a little choppy so I figured it might have cavitated. I let off, it hooked again so rolled back to crusing speed, everything was ok. On the way home I took off out of a no wake zone a little faster than normal and it slipped again. Again I figured cavitation becasue this has happened once or twice while getting on plane. When I got home, was flushing the motors and my buddy noticed the prop spinning when in neutral.....this points to tranny and supports the slippage....
Fluid looks/smells normal. Is there any adjustment in these? Any hope NOT pulling/replacing? Any thoughts are appreciated.
10M is offline
Old 07-10-2011 | 02:18 PM
Prop spinning in neutral while running out of the water is normal. Don't believe there are any external adjustments you can make besides the shift cable. Maybe it could be the prop hub slipping though I think it would be doing it more often. But then you would think the trans would be doing it more often also.
picklenjim is offline
Old 07-10-2011 | 08:48 PM
10M
I've seen the props rotate a little, but this one spins pretty fast and the other one barely spins at all in neutral (on trailer @ idle). Also my buddy said it was spinning faster this time than last time.
Could it be that the cable needs to be adjusted, and the revving was just cavitation? Or does a worn-out trans mean it stays engaged and slips? I have no idea how these work.
I wouldn't have thought twice about the revving bc I wrote it off as cavitation, but the fact that one prop spins in neutral and the other doesn't has me thinking. Also I've never had it cavitate while planed off @ speed, those TRS's are pretty deep and i'm careful about throttling when it comes out of the water.
10M is offline
Old 07-11-2011 | 03:18 PM
10M
TTT
Any ideas on this?
Thanks for any replies
10M is offline
Old 07-11-2011 | 03:34 PM
If the tranny slips it doesn't spin.
MikeyFIN is offline
Old 07-11-2011 | 03:58 PM
Rookie's Avatar
Originally Posted by 10M
TTT
Any ideas on this?
If you already haven't done it, change you fluid. Mine was slipping last year and it was due to water in the tranny fluid. Had tranny rebuilt this winter.
Rookie is offline
Old 07-11-2011 | 04:08 PM
Default tranny
Mine has been doing the same thing for 2 years and I am pulling the motor and trans this week. I was told the clutchs are sticking together. My mechanic said it would be fine just a little harder to dock around the docks. The only reason I am rebuilding it now is because we have to pull the motor to install a new flywheel on that motor. Run the he!! out of it and it should be fine for this season.
PROTOTYPE28 is offline
Old 07-11-2011 | 04:27 PM
Default Fixx
the trans may be sucking air..the aZZ end of the fountains sit so low in the water and when you go to plane off all the transmission fluid goes to the back of the trans and the pick up tube in the trans is forward..theirs a modification you can have done to the pick up tube,,it can be extended to the rear of the trans so it wont suck air..
If you change the fluid make sure you use "F" type.
FIXX is offline
Old 07-11-2011 | 06:17 PM
Slipping while underway has nothing to do with the prop spinning while running in neutral on the trailer. If it loses pump pressure to the clutch pack momentarily it will slip as Fixx mentioned. When the prop spins like that in neutral with zero load on the prop either the plates are dragging a little due to some warpage or the clutch pack is setup a little tight. The fluid spinning between the plates can be making them all spin together also. Whatever spinning on the trailer while in neutral is pretty normal.
Old 07-12-2011 | 08:43 AM
10M
Ok thanks that's what I wanted to know. Was just a little confused about why one spins and one doesn't...and the one that spins goes pretty fast now. They used to act the same @ idle in neutral, so something changed. I will change the fluid and try it again, keeping an eye on whether it gets worse. Warped plates wouldn't surprise me I guess, she's an old gal and I have no idea what kind of service and usage the trans have had in their 23 years.
Thanks again.
10M is offline
