1995 272 inslander prop? >
Old 07-11-2011 | 03:11 PM
Default 1995 272 inslander prop?
I am having trouble with my prop like spinning out. I had a 3 blade prop with a pitch of I believe it was 23 or 24 it would always spin out when I pulled a tub with 3 people on it. I was told to get a 4 blade 22pitch and that will eliminate the problem. I got one and i was at the lake this past weekend and had 9 people in my boat and it spun out 3 times. It spins out when I go to give it gas and sometimes take off. It also sometimes spins out when i turn and give it gas. Should I have a different pitch does anyone else have this problem? What should I do?
Thank you!
mespey08 is offline
Old 07-11-2011 | 03:56 PM
wow - 9 passengers and pulling a tube? id say your props are exactly what you should be running assuming stock power. my guess is you are having weight issues and are blowing out trying to get up to speed with that big load. does it do the same thing with say half the amount of people and coolers in it?
will22 is offline
Old 07-11-2011 | 04:23 PM
I do not pull a tube when I have that many people... With 9 passengers and coolers it spins out
mespey08 is offline
Old 07-11-2011 | 05:13 PM
What do you mean by spin out? Ventilating, as in your prop pulls air from the surface, won't bite and revs up?
How much power do you have? The four blade is a good idea for tubing, but with that heavy a load, I would look into a Revolution 4 in a 19" or maybe 21".
Also. Give us some details about your gps speed @ ??? rpm's ect. What make and model props are you running? It's hard to help without this info.
A.O. Razor is offline
Old 07-15-2011 | 10:45 AM
252 Baja's Avatar
If you have PVS holes in the prop, you might try smaller holes. I have a Rev 4 on my 252 and it never blows out.
252 Baja is offline
