yellow bottom.
Old 07-11-2011 | 08:16 PM
STRAIGHTPRIORITY's Avatar
Default yellow bottom.
i have never had a problem with my bottom turning yellow, but i recently moved to a canal and it turns really yellow in one night.
i like to keep it at my house on the weekends. i dry store the boat.
i guess my question is. what can i do to prevent it over night?
shpuld i wax it more often... what wax
it gets exhausting having to on off it every weekend.
does anyone else have this problem? is it the canal?
I was talking to my father and he said it because the canal is very tidal and the water is so warm.
It makes it look like i dont care for my boat.
Thanks for any help boys
STRAIGHTPRIORITY is offline
Old 07-11-2011 | 08:26 PM
GO4BROKE's Avatar
If you put wax on, and don't buff it off, it will slow the stain. On Off is pretty harsh just to clean that. FSR is mild and works very well. Power 1 is a little harsher, but works very well. The only way to prevent it would be a lift or one of those pool style setups that let you chlorinate the water around the boat.
http://www.clearmarine.com/bath.php
[img][/img]
GO4BROKE is offline
Old 07-11-2011 | 08:34 PM
i was gonna try a good coat of wax. i guess if it doesnt help i will just bring it back to the marina every night. i appreciate the input.
Rob
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You want to pick up some Slimy Grimy.
http://www.slimygrimy.com/
I've been using the granules in a garden sprayer for years, and it works great.
Sydwayz is offline
Old 07-11-2011 | 09:01 PM
inbetween's Avatar
I'd rather be boating!
Cheap toilet bowl cleaner in a garden sprayer works well for cleaning and won't break the bank
inbetween is offline
Old 07-12-2011 | 01:33 AM
Nothing you can do to prevent the staining. Lots of products are easier to use than On/Off. Use some Works or Sno Bowl toilet cleaner in Pump garden sprayer. You can use muratic acid also. I can do the bottom of my boat in 20-30mins easily. Just make sure to rinse it off very well.
Griff is offline
Old 07-12-2011 | 06:01 AM
BillR's Avatar
OSO Moderator
on off is VERY harsh. The more you use it, the easier the gel stains.
Look / Search for a pool product called Ringo. It's a red gel that won't harm gel or you, no fumes, can be applied with bare skin.
as far as keeping the stain off, try using Future floor wax on the hull. Some have reported 100% success with it.
Most importantly - stop using on/off!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-12-2011 | 07:25 AM
Knot 4 Me's Avatar
I cut some Works 50/50 with water.
Knot 4 Me is offline
Old 07-12-2011 | 07:51 AM
glassdave's Avatar
Neno the mind boggler
our lake and river here always leaves a stain when i put the boat in even for just a day. I use to use Sno Bowl and all the other harsh stuff but found PowerOne last summer. It use to be a huge chore keeping the boat bright white and now when i pull the boat on sunday i just leave it dry till the next day and walk around with a squirt bottle and thats it then i just hose it off. I went from a few hour chore to just a few minutes. (works best on a dry surface)
http://www.fountainofyouthrestore.co...wer_One_1.html
08 OPA High Points Champion
glassdave is offline
Old 07-12-2011 | 08:30 AM
i appreciate all the input.. i will try them all.
when i use on off i dilute it with water. i have maybe used it three times total.
i have never seen yellow show up so fast.
i guess it will have to be part of the regular maintenance... like flushing it.
