New prop, need a spacer?
Hey guys,
I just picked up an older Mirage 21" prop for my 90 Scarab (350mag alpha 1)
My current prop is a Merc Rev4, 21" with a 2 piece hub setup. It looks like my new prop just needs some sort of splined spacer. Here are some pics, any / parts suppliers?
New Prop:
Old Prop:
Thanks!
-Rob
New Prop:
Old Prop:
Thanks!
-Rob
You need,
31211Q3
Brett
31211Q3
Brett
[email protected]
[email protected]
the part looks just like the brass piece you are using on the old prop, except the part is just the end without the long squarish tube thing that slides in. Basically any place that has boat parts should have it on the shelf as it is a common item.
Good description However, it's not as common as it used to be.
The part number is above and if you cant find one, we can send onr to you.
Brett
Brett
[email protected]
[email protected]
